Xiaomi Smart IP Camera 1080P Funk WLAN WiFi
      Xiaomi Smart IP Camera 1080P Funk WLAN WiFi Video Überwachung Webcam Babyfone EU
      BESCHREIBUNG
      Worry about your home security when you’re out? IMI Wireless 1080P Home Security Camera lets you see your home clearly day and night, directly from your smartphone or tablet. It provides a 360° coverage and up to 1080P HD resolution videos. Advanced Wide Dynamic Range (WDR) balances out the bright spot and the dark areas and enables you to see more details clearly in bright and dark light. You may also talk to your family directly through your phone to your camera anytime and anywhere. And when motion is detected, it will trigger a video recording and alert you. Get this camera and keep an eye on your home and beloved ones 7 / 24.
      Features:
      Full HD 1080P and Complete 360° Coverage: 1080P full HD resolution enables you to watch crisp, clear and detailed live and recorded video on your iOS and Android device with the free Mi Home app. The 110° wide-angle lens combined with 360° horizontal & 110° vertical rotation range creates a complete 360° coverage, effectively reducing blind spots.
      Support WDR: Advanced Wide Dynamic Range (WDR) balances out the bright spot and the dark areas, enables the camera to record more detail in contrasting light areas and allows you to see more details clearly in bright and dark light.
      7 / 24 Real-time Monitoring: By connecting the camera to a 2.4GHz (not support 5GHz) Wi-Fi network, with the free Android / iOS app, you can watch live videos, control the pan / tilt function, playback videos, take screenshots, and more, anytime, anywhere. With the same app / account, you can also remotely access the camera with other smartphones or tablets. To protect the privacy of your family and visitors, you can also set a timer to let the camera go to the sleep mode.
      Enhanced Night Vision and Clear Two-way Audio: Supports full color display in low light. 8pcs 940nm infrared LEDs automatically turn on in low light environments, letting you see up to 16 feet clearly in darkness, no disturbing red light. The hand-free mode lets you talk with your family clearly and smoothly with your smartphone or tablet from anywhere.
      Motion Detection & Alarm Function: When motion is detected, a 12s video clip will be automatically saved to the cloud for 7 days (free of charge), and a real-time alert will be pushed to your smartphone.
      Support Local Storage and Cloud Storage: The built-in TF card slot supports up to 64GB TF cards (TF cards not included). It also supports NAS storage and free 7 days of cloud storage. The FAT32 format is required for a 64GB TF card.
      Easy Installation and Setup: You can mount the camera on your wall, ceiling, or table. Simply connect it to a power supply, download and open the Mi Home app, and follow the on-screen instructions. With voice prompts to facilitate the operation.
      Specifications:
      • Brand: IMI
      • Color: White
      • Camera Angle: 110° wide angle
      • Resolution: 1080P
      • Focal Length: 2.8mm
      • Pan / Tilt Angle: Pan: 360°, Tilt: 110°
      • Connection Type: WiFi: 802.11b / g / n 2.4GHz Only
      • Operating System Requirement: Android 4.4 or iOS 9.0 and above
      • App: Mi Home app
      • Night Vision: Infrared night vision (8pcs 940nm infrared LEDs)
      • Night Vision Range: Up to 5meters
      • Two-way Audio: Yes
      • Motion Detection: Yes
      • TF Card Storage: Support up to 64G TF card (TF card not included)
      • Power Input: DC 5V
      • Cable Length: 2 meters
      • Operating Temperature: -10°C ~ 50°C
      • Product Dimensions: 115x78x78 mm
      • Product Weight: 239g
      • Package Dimensions: 90x87x160 mm
      Package Contents:
      • 1 x 1080P Home Security Camera
      • 1 x Power Adapter
      • 1 x Wall Mounting Accessories Pack
      • 1 x Power Cable
      • 1 x User Manual
      computerbild.de/artikel/cb-New…Deutschland-24008157.html
      mi.com/de/
      mi.com/global/camera-360
      :pfeilrechts: gekauft, mal sehen ob es was taugt.
      Images
      Hatte für die Ferien-WG erst mal eine gekauft zum ausprobieren!
      Das ist eine geile WebCam, die gefällt mir sehr gut!
      :pfeilrechts: Habe heute gleich noch 3 weitere gekauft! :thumbsup:
      Preis bei 3 WebCam's 37,59 Euro/WebCam, sonst 39 Euro/WebCam verhandelt! Normal bei diesem Händler heute 39,99 Euro.
      Als Überwachungs-Cam hatte sie ihren ersten Einsatz:
      Den Einsatz von Minol hat sie erkannt!
      KINGSTON Canvas Select, Micro-SDXC Speicherkarte, 64 GB, 80 MB/s
      :pfeilrechts: Dazu folgende Speicherkarte gekauft (Preis heute 9,99 Euro/Karte):
      Kingston microSDHC-Karte UHS-I mit AdapterUHS-I Geschwindigkeit in einer kleinen, langlebigen Karte.
      45 MB/s Lese- und 80 MB/s Schreibgeschwindigkeit in UHS-I Klasse 10
      kleiner Formfaktor
      robust, um Ihre Fotos und Videos auch bei rauer Witterung gut geschützt zu halten.
      Speicherkapazitäten von 8 GB bis 128 GB
      Kingstons microSDHC/microSDXC Karte UHS-I Klasse 10 ist mit 45 MB/s Lese- und 80 MB/s Schreibgeschwindigkeit in UHS-I Klasse 10 ideal für Fotografen, die von Standbildern zu Bewegungsbildern mit Kindern und Tieren alles aufnehmen. Sie ist auch bestens für HD-Videos* in Kinoqualität (1080p) geeignet und reduziert, im Verhältnis zu Karten der Klasse 4, die Pufferzeit zwischen den Aufnahmen.
      Die microSDHC/microSDXC UHS-I Klasse 10 ist die kleinste SD Karte am Markt und passt in viele Tablets, Smartphones und kleinformatige Kameras als Standardoption zur Speichererweiterung. Sie kann mit dem optionalen SD Kartenadapter auch in SDHC/SDXC Hostgeräten in Standardgröße verwendet werden.
      Diese Karte ist langlebig und für extreme Wetterbedingungen geeignet, und wurde auf Wasserdichtigkeit**, Beständigkeit gegen extreme Temperaturen***, Erschütterungs- und Schwingungsfestigkeit**** getestet und ist röntgensicher*****. Bei Speicherkapazitäten von 8GB bis 128GB finden Sie mit Sicherheit die Karte für Ihren Bedarf, damit wieder Platz für Tausende hochauflösender Fotos und stundenlange Videos ist******.
      Images
      Die Begeisterung von der WebCam hat sich mittlerweile gelegt!
      Die WebCam steigt nach einer gewissen Zeit einfach aus und ist dann Offline. Dann tut sich nichts mehr!
      Ich werde das Ganze noch eine Weile beobachten.
      Ich vermute mal es handelt sich hier halt um China Schrott!
      Wenn die Kontrollleuchte blau leuchtet:
      1. Überprüfen Sie, ob der Router, mit dem die Camera verbunden ist, ordnungsgemäß funktioniert
      2. Starten Sie die Xiaomi Home-App neu
      3. Trennen Sie die Kamera von der Stromversorgung und starten SIe die Kamera neu, indem Sie sie wieder an die Stromversorgung anschließen.
      Nach einem Neustart blinkt die blaue LED die ganze Zeit:
      1. Wenn die Kontrollleuchte während der Konfiguration der Netzwerkeinstellungen blau blinkt, bedeutet dies, das die Kamera keine Verbindung mit dem WLAN herstellen kann oder nicht mit Ihrem Konto gekoppelt ist werden kann. Dies könnte auf einen Fehler in den Netzwerkinformationen hindeuten.
      2. Wenn die Kontrollleuchte während des normalen Beriebs beginnt, blau zu blinken und die Kamera nicht mehr funktioniert, bedeutet dies, das ein Netzwerkproblem besteht, das selbst gelöst werden muss.
      Gründe, warum Ihre IP-Kamera keine WLAN Verbindung zu Ihrem Router herstellenChecken Sie die folgenden möglichen Gründe, warum Ihre IP-Kamera keine WLAN Verbindung findet oder warum das IP Kamera WLAN nicht funktioniert.
      #1. Die Antennen der WLAN IP-Kamera sind nicht gut befestigt – die Antennen sind lose.
      #2. Ihre WLAN IP-Kamera ist nicht mit Strom versorgt.
      #3. Sie geben das falsche Login-Passwort ein.
      #4. Die SSID der IP-Kamera ist nicht gleich wie die Ihres Routers.
      #5. Die WLAN-Reichweite ist zu klein – die IP-Kamera ist zu weit vom Router entfernt.
      #6. Die drahtlose WLAN IP-Kamera erhält eine falsche IP-Adresse.
      #7. Die Firmware oder die Software ist veraltet.
      #8. Sie konfigurieren niemals die WLAN-Einstellungen Ihrer neu erworbenen Überwachungskamera.
      #9. Ihr Router unterschützt den WLAN-Kanal Ihrer IP-Kamera nicht.
      Nachfolgend sind einige mögliche Ursachen, die dazu führen, dass Ihre IP-Kamera nicht mit Ihrem Handy verbunden werden kann oder dass Sie immer den Status “OFFLINE“ sehen, wenn Sie versuchen, eine Verbindung herzustellen.
      #1. Weder die IP-Überwachungskamera noch Ihr Telefon stellen eine Verbindung zum Netzwerk her.
      #2. Die Option “UID“ Ihrer IP-Kamera wurde noch nicht aktiviert.
      #3. Sie haben die Firewall Ihres Routers aktiviert und der blockiert die Verbindung.
      #4. Die Firmware oder die Software ist veraltet.
      :pfeilrechts: Quelle: reolink.com/de/loesungen-fuer-…ra-keine-wlan-verbindung/
      Files
