NetUSB-400i
Features
- Controls 4 USB 2.0 devices located in the LAN
- Auto-detecting 10/100Mbps Ethernet interface
- Driver automatically finds USB servers on LAN
- Supports Windows XP, Vista
- Protocols TCP/IP,UDP, HTTP, DHCP,ICMP,DNS
- Administration Software
Overview
The NetUSB-400i controls four USB 2.0 devices via Ethernet. The four USB ports on NetUSB-400i are seen as installed in the Windows PC. Any devices connected to the ports are detected via Plug&Play. Several PC may use the same devices on a time-sharing base.
USB printers offer an automatic sharing option, to connect them when data is printed. Other PC use the same printer as soon as the previous job has finished printing.
The metal case and the flexible power supply make the NetUSB-400i a good choice in rough office and industrial environments.
Read the News Article…
Application
Print server
- Automatic warehouse control system
- Retail system Remote surveillance
- Building automation system
- Other remote USB devices control
Hardware
- Processor ARM 9 170 Mhz
- Memory 32MB SDRAM, 8 MB Flash
- Connector type USB type A Port
- RJ45 for Ethernet
Interface
- Ethernet interface Auto-detecting 10BaseT/100BaseTx
- Protocols TCP/IP, UDP, DHCP, ICMP, HTTP, DNS
- USB interface USB 2.0 High Speed
- No. of port 4
- Available Modes Bulk transfer
- Isochronous transfer
Performance
- Speed Up to 480Mbps
- IRQ None
- IO address None
Power and Environment
- Power requirements 9 - 30V DC, 1.2A @ 12V
- Dimension 127×92×27 mm³ (W×L×H)
- Operating Temp 0°C - 55°C
- Storage Temp -20°C - 85°C
- Case SECC sheet metal (1mm)
- Weight 300 g
Special Features
- Installation Administration utility automatically finds USB servers in the network
- Configuration Configuration over Driver Panels, WEB Browser
- DNS Domain Name Server support
- Firmware Firmware update over Administration Software and WEB Browser
- LEDs LEDs for Power, Ready, Ethernet Link/Speed, USB usage
Features
Overview
Application
Print server
Hardware
- RJ45 for Ethernet
Interface
- No. of port 4
Performance
- IRQ None
- IO address None
- Weight 300 g
Special Features
