Dewitt wx-1.36.m1100
Code ID8406
Aufzug Automatik
Material Gehäuse Rotgold
Zustand 0 (neu)
Neu/gebraucht Neu
mit Box
mit Papieren
Standort USA, New York, Airmont
Preis $ 585.000 (= € 423.637)
Werk
Aufzug Automatik
Gehäuse
Durchmesser 48.64;72.51 mm
Höhe 21,17 mm
Bemerkungen
Strictly a limited & Numbered edition of 33 pieces world-wide.
The watch made it debut as the "Incognito" when DeWitt offered the watch for auction at a Charity event. The offer was for a watch in concept only without being presented & without the buyer knowing what he was buying. The wining bid was for 400,000 Euros.
This watch features: Extraordinarily generous case dimensions. Case manufactured from a combination of 18kt Rose Gold, Titanium & Aluminum which allows the weight of the watch to be kept at a minimum.Dial apparatus protrudes from the watch edge. Time is read by a minute disc roting clockwise & the hour disc rotating to the left. this is accomplished by an ingenious gear system that is mounted on 6 runners.Branded 18kt Rose Gold Deployant buckle.Crown at the 3 oclock position is used to set the time (does not wind the watch)To the left side there is a distinctive "porthole" from which the 1 minute tourbillon can view.Also on the left edge is the crown to wind the watch - this crown can be recessed into the case. The watch is provided with a battery operated device that will wind the watch easily. The battery operated winder has a resistance feeler as to stop winding once the watch is fully wound.The watch has a 21 day (504 hours) Power Reserve, energy is stored in 5 separate barrels - all lined up vertically.by pressing a lever on the case edge at the 9 oclock position the encased movement slides out of the watch case where you can view the vertically mounted gear train, barrels Power reserve indicator & Tourbillon cage.A true collectors/investment piece
:arrow: Das DIng kostet schlappe 423637 Euro
Hier der Link dazu
Code ID8406
Aufzug Automatik
Zustand 0 (neu)
Neu/gebraucht Neu
mit Box
mit Papieren
Werk
Aufzug Automatik
Gehäuse
Höhe 21,17 mm
Bemerkungen
Hier der Link dazu
